- New Jersey
I've been having trouble tuning my 650sx. The only upgrade I have on it is a mikuni 44sbn. I just replaced the reeds (which I thought might've been the problem). It's very unresponsive. Also, I can go out on it and it will run ok (not great though) and then 10 minutes later it will barely go over 5mph. It just seems to have a mind of its own. I need to check the compression again (I checked at the beginning of the season and it was about 147 in both), but does anyone have the same setup and is able to give me a starting point for pop-off pressure, jet sizes, and where your needles are? I just pulled the plugs and the rear plug is a solid brown color (similar in color to rust) and the front plug is just a little darker brown and a little wet.
