- CT
if you pull your plugs from your ski right after letting it idle in the driveway are they supposed to be wet or dry? also, when im riding and i jump out of the water i take my finger off the throttle, but the motor seems to still be reved up until i land again. what does that indicate? and as i try to tune my low speed screw with the ski on the trailer backed in the water everything works perfect like group k syas it should. i turn in the low speed screw until it cuts out and that whole thing. but then when i ride it doesnt hit hard at all, it boggs. at that point the screw is at 3/4 turns out. when i go to 2.75 turns out it acts alot better but not perfect
