Turfing the rails question
I would like to turf the rails on my SquareNose. Anyway, is there a lot of maintenance that goes along with it? I have read about filling in the holes and sanding down the turf towards the bottom and whatnot, but will I be having to re-glue after every ride?
Tanman
Jus' keep er' pinned
Ketchikan Alaska
idk i did that to my Sn, i filled in the little ridge where the stock caps go and all the wholes and then painted my whole ski. and ya i rip some edges up everynow and then but if you cut your edges nice and flush and glue like a mad man you should be good. mine are fine and i can't imagine good tricks without the grip
kraqus
A good turf job will last more than one season. Got to do it right though.
Anyone has pics of a SN with the rail turfed? How did you get the turf to curve on that lip?
It is way different than a RN where is one shot straight down......
Benny
Crab
thanks darin...noswad!
Seattle
heat, cut the edges at a 45 degree and they won't lift.
58vwragtop
Braap Certified
Blue Springs, MO
I turfed my sn. if you want to see some pics you can go to my album here on the X. It pretty easy, I'm on my 2nd season with the turf and it is holding up great. I left the rail caps on when I turfed, some people take them off and turf directly to the ski. I didnt even use any heat, just use 2 coats of the contact cement and let it dry up (haze) totally before putting together. Also some small clamps with paint sticks between them work pretty good
Big Kahuna
Administrator
Tuscaloosa, AL
sand the edges at 45 degrees. Where the turf meets the hull, tape off over the turf right up to the edge, and then tape the hull leaving a small gap. Take black RTV silicone and run a small bead forcing the silicone into any gaps. Then spray WD40 on your finger and pull it down the length wiping up any excess. Remove tape immediately, go slow. This will help keep the water from getting under the turf. You can allso run a small bead of superglue at the edge where you bevel it to help keep water from getting up under it.
kraqus
That was an awesome job.
Benny
SJBrit
Extraordinary Alien
Bradenton, FL
Good tip on the WD40 BK - saves a lot of finger clean-up afterwords!!
Here is our squares right after the turf was put on, I didnt put enough of an angle on the bottom so my turf lasted about one season. the other had more of a bevel on the bottom and hasnt had any problems in 2 seasons now. we kept the screws visible so later if we had to take the rails off, we could do so easily. prep is the key with all turf. make sure surfaces are clean, a little roughed up for adhesion, and we always wipe down surfaces with either acetone or alcohol. (rubbing 91%.... crown royal probably wont work.) Use a heat gun to make the bend... lots of heat! careful not to burn, and two layers of glue works better than one. IMO. A hot razor knife with slide through turf like butter. Good luck, its worth it. :smoker:
heres mine with turfed rails and nose
i havent had any problems, just make sure you do two coats of contact cement on both the ski and the turf
I bought the side rail turf from Blowsion. The back section that angles up is already cut and it fits great. I didn't fill in any holes and I just sanded/cleaned off the old turf. I made sure the ski was clean and applied glue to both the turf and the ski and haven't had any problems with it coming off yet.
JustinB
Proof I has a brain \l/
Oxford, MS
Here is mine. I didnt fill any holes, and I cut the bottom edge with a razor blade.
