- Clearwater, FL
hey FLY6584 could you post some more pictures of your turf?
The only picture I have of mine I already posted earlier.:biggthumpup:
The best way to apply it is to apply a thin coat and let it dry to a tack then apply another coat and let that dry to a tack (To both the turf and tray). Then you stick the turf down and be careful cuz once you stick it down its down.
Just to keep this all in one thread. Are the most of you guys using the cement Hydro-Turf sells or something else?
Also what options are their for padding other than Hydro-Turf expensive stuff?
Which makes me think that using a heat gun to get the turf formed to the sides would be best done before you lay the glue down. Or does it not work as good because the glue isnt holding the bottom down?
