Turn your iPhone into a thermal imaging camera!!!
RivMan
doing something stupid...
Pinckney, MI
Engine with Marine exhaust manifolds
Circuit board
Trailer hub running a little hot
SuperJETT
none
Here are some shots of my basement rim joist area back when I was sealing things up.
Granted, this is a $14,000 FLIR T440. These are the fusion pics with the visible layered behind the thermal.
OCD Solutions
Rentz, GA
How far away will it pick up heat? Can you pick up say a person from 10 yards? 50 yards? 100 yards?
Make a list of what you wanna know and I'll try to set up the scenario and post a pic.
I plan to try it out in the yard to see if I can spot what's crapping in our front garden.
Quinc
Buy a Superjet
California
I am sure I will come up with more. :)
-Water temps
-Distance
-How hot does something need to be to pick it up behind something like a wall, or sheet of plywood
-Does it work outside on a hot day
OCD Solutions
Rentz, GA
Seeing shapes and objects behind walls, windows, tents, etc is Hollywood BS. Thermal cameras can only see surface temps, not through walls like they depict.
OCD Solutions
Rentz, GA
Yes, It will detect the heat emitted from the pipe that transfers to and through the wall and you will see a general pattern. You have to play with the temperature range to capture differences in temperature. That can be really tricky. Sometimes you actually have to cool a surface briefly or inject a temperature for a brief time and then watch as it transitions. A pipe or hot wire in a wall is pretty straight forward but capturing the level inside a vessel can be quite challenging.
Reflective surfaces are a thermal cameras nemesis. For instance, If I placed my hand on a pane of glass, it would see the outline of my hand. If I held it with a 1/4" gap, it will likely still see it but with much less clarity. More than an inch away and you would likely see nothing.
There is a much higher chance of seeing the reflection of my own shadow reflected back from the glass, than there is of seeing my hand on the other side of the glass. It's an odd scenario and it takes some playing to wrap your head around what the camera is actually able to pick up. When dealing with shiny surfaces, you actually have to take great care to be sure the images on the screen are behind the surface and not reflected onto it.
Somewhere I have a video of us shooting a motor control center and I'm waving my hand behind the techs head, and the camera is capturing it reflected back off the shiny grey surface of the cabinet.
Someone let me borrow this iphone infrared and ill let you burn stuff with me :)
OCD Solutions
Rentz, GA
It was finally here when I got home last night so I ran around and shot everything I could with it, including my sleeping wife but the responsible me already deleted those pics. :)
Delaware
How are you guys liking these after having to some time?
Been on this kick of wanting to pick on up to analyze my and others houses that are older and may not be insulated well.
