Super Jet Twist Girdle Head need help!
I use to race back in the 90's and have a Twist Girdle head that I want to install on a 95 Superjet I just purchased. The question I have is where do I get a head gasket to use with this head and I would also like to get new o-ring for the domes .
Thanks
PNW
Call MSD and see if they have any NOS gaskets left. I was able to buy a new dome for my twist head a few years ago.
88kawi5fiddy
pew pew lazers!
So Utah
bearing supply stores should have the o rings.
as for the head gaskets, i have a few but i dunno where to get new ones. probably make one?
i have an older twist head, and it's got just the orings I believe, if I used a gasket it was a stock one but I am pretty sure I didn't use a gasket because the water porting on the head is completely different than stock. Mine isn't the sawblade design, it was one before that I believe
The one I have is the saw blade type and I remember using a gasket but it was not the stock gasket. I remember it being very thin as it wasn't copper.
