Custom/Hybrid Type 9 pipe water routing
Hi justin. Just one question. I found main 135 jet and pilot 75 jet.
Also found needle and seat 2.0. How many grams for the springs? Cheers m
Inviato dal mio iPhone utilizzando Tapatalk
Quinc
Buy a Superjet
California
Cool! Thanks justin for all your help!!! Gonna buy the stuff, set everything up and i ll let u know how it goes
Hi justin. I set all up and it should be ok. Just one question regarding the type 9 pipe. Just close to the manifold 90 degree water inlet there is another small straight inlet. What is that for? Which water line do i have to run in there?
On the manifold there are 3 inlets one on top two on bottom the one on top and one on the bottom are there to feed water to your motor.
The other one on the bottom is where u would run the spray ring for water injection. If u can I would run two lines in on the manifold. What kind of rpm do u run on your ski if your running more then stock u might run into a over heating problem. I just put a new cdi in my ski and now full pinned from more then 30sec it trips the heat sensor but resets after about 30sec. I change it and ran two lines into the manifold and there is no problem with over heating now
Actually i just have one big inlet in the manifold. the other one is tiny and straight. I should take the engine out and make another inlet in the manifold but not for this season time. So, for the big manifold inlet i run one line directly from pump. And the other little one?
Yeah it well work but top end if it can't keep up with how much your putting out then u can run into a over heat. If this happens then add another inlet and just pre heat the water into the pipe
Hi justin. I just have set the carbs with new jets.
What about the screws now? High speed and low speed screw i mean. How many turns out do u suggest? Tnx
