Super Jet unbreakable stainless steel coupler cover
ThatGuy
NJ
This is after 2 hours or riding.
Not sure everybody has the same definition of unbreakable but.......
To be fair this just happened and i have not contacted them yet to see if the will be replacing for free i would hope the would.
I have yet to see a coupler cover that is better or cheaper or more durable than the stock one.
That said, I'm sure Blowsion will take care of you.
ThatGuy
NJ
Yea its back to the cracked stock one I think I am going to order a extra stock one to be prepared if this happens again. At least if it goes i don't really have to worry about damaging the coupler since it is plastic. Good thing i ran out of gas right after a big air only to find it resting on the coupler.
dfw
Everyone just got a lesson in metal fatigue. There needs to be rubber isolation mounts on the engine side. Or just make the part from composites.
SuperJETT
none
Stock or one that mounts to the hull, those are the only ones that last in my experience.
ThatGuy
NJ
Agreed it did come with rubber isolators but i guess they were not up to the task.
waterfreak
I had a vision!
Vendor Account
s florida
that's what I did with my stainless blowsion one. My new carbon cover is bullet proof!
Vumad
Super Hero, with a cape!
St. Pete, FL
cut little pieces of fuel hose use washers to make an isolator..done
If an aftermarket part like that requires additional modification or parts, it is not worth buying. Buy bolt on or buy stock which bolts on.
What exactly is wrong with stock? Do they break a lot?
JPCharmin
just order him a turd
Houston
i had the exact same thing happen to my stainless coupler cover with the rubber isolators/grommets installed.. the thing is a piece. If your going to go with anything other than stock go with the wamiltons carbon coupler cover, def not cheaper though.
