WFO Speedracer
- Alabama
Pickups on these are fixed an no way in hell you are moving it 17 degrees and keeping it stable and in place, they broke pickup brackets as they were stock, the timing is adjusted with a hand held programmer and since he has rigged this there is now no way to adjust the timing except by continuing to rig stuff up, good luck going down this road , it's a bad road but it's yours to go down, I am just glad it's you and not me.Ok, so assuming your marks are correct and your light isn’t set for any advance and your TDC mark was accurate, your pickup would need to move 17 degrees. Should move so it’s triggered 17 degrees later. This tells me your ignition expects a static angle of 64. Did I math that correctly? I think someone said the factory static angle on 788 is 47, right?
Actually, looks like your curve doesn’t hit full timing advance until 3k. The fact you see the same timing from idle on up is fishy. You need to see what the mark is at after 3k
