- near beautiful bobcaygeon
I am changing the impeller on 4-stroke superjet.
1.a) When i re-install the reduction nozzle to the pump body casing it looks like i should use silicon or something to make seal; is that right and if so what is best to use?
1.b) Similarly, when i re-install the entire pump body back onto the hull should i use some kind of sealant there, and if so what is best?
