Super Jet Used 6M6 Superjet parts fitting a 91 superjet with 6R7 part numbers
On my 91 650 superjet, I traced down and think my troubles are with the CDI and ignition coil. My part numbers for these pieces start out with number 6R7-00. I ordered in a used superjet CDI and ignition coil with part numbers 6M6-01. Will they work on my 91 superjet? Thanks in advance for your trouble.
I'm pretty sure it will work. The only difference between the 650 cdi's and the 700 cdi's, from what I understand, is an increased rev limit from 6500 to 7000. Other than that, I thought all the cdi's were interchangeable. What was your bike doing that makes you think you need a new cdi (I'm trying to troubleshoot a 650 myself right now)?
if you're getting those parts from penny1l that are in the pics I think those part number differences are nothing to worry about. Did you attempt to ohm out those stator coils or the ignition coil?
Pistolgripump.... I had no spark from the plugs. I replaced the ignition coil(since it was already thrown out) and the cdi. I now have spark. Still think I might have a little bit of carbureator issue though.
r6487... I did ohm and check the volts on the stator. Mine is ok. The old ignite coil was thrown away and did not get achance to ohm it. When I first installed the ignite coil and cdi, it started right up and sounded good but after aliitle bit of trying it out, it seems to bog down when giving it throttle and die. I had also pulled the carbureator and cleaned it so I might not have adjusted the screws right. It is a stock carb and I adjusted to 1 1/2 turns on each.
