Picked up my first superjet last week - a 96 RN. It had a stock head that was milled as it tested 180/179 on my gauge. It wouldn't start so after a bit of haggling ended up with a semi-risky but non-covid priced ski.
It had a b-pipe but the screws were frozen so I pulled the headpipe off to get to work on those. First thing I noticed was the oil in the bottom of the ex manifold - could that be from his quoted "winterization" or is it a red flag? I also noticed it was an early production b-pipe with only a 42mm opening so I'll open that up to 47mm soon enough.
Next I pulled the ex manifold to clean that up and port as well. Below is a pic of the PTO piston - I tried to compare to other pictures I found but is that just some scuffing or is it heat damage from the color change?
Should I tear this all the way down now? If it passes a leakdown test could I just run it for the last 2 months of the year or is that asking for issues? Deciding which way to go next as I currently wait for some parts from Jetmaniac.
