Using Devcon putty to fill 62t cases
Crankcase epoxy
I have used many different products to epoxy cases & intake manifolds over the years. The Devcon does seem to shrink, and is too expensive. I agree that Marine-tex is a good solution, but it's messy and heavy also.
I sell A-B Epoxy to many builders. and have had excellent results for years. One of the benefits besides "low price" is that it's "non- metallic" and has no metal filler like Devcon.. If it becomes dis-lodged and enters the combustion chamber, it crushes easily and won't cause any internal damage on the way out the exhaust port. It's easy to mix and apply, you can smooth it with water to reduce the finish work later.
I like to beadblast the crankcases, manifolds, etc before applying filler materials. If you cannot blast them, then you might try scuffing the surface with a fresh "sanding roll". http://www.watcon.com/Catalog_Pages/AB_Putty.htm
Thanks,
Randy
just joe
NorCal
In my experience with shifter kart motors (very high rpm, extended periods) the best bet is regular 2 part epoxy (A-B or US Composites stuff) for intake manifols/carbs. It holds as well as any other, and when it does start to crack it is easily consumed and digested without substantial damage, as previously stated.
I don't know how well the US Composites epoxy would work in a case, though. Intake it's fine (same material glass reeds are made of).
wildman326
Who else?
Kansas
Here's a few pics of the cases I'm going to use on my Lamey Cylinder. I had to do massive porting on these because the Lamey has so much more transfer clearance at the cyl to case union.
I've had JB weld stick and also had it come off. Same with the marine tex paste. I've heard that the media blasting is very important and blasted these before I filled them.
I finger-ported and filled these with my last motor and needed to do a re-port to match the Lamey. The first pass of JB weld stuck very well and has lasted at least 2 seasons.
Even when I blew a cylinder and had to use stock cylinders for a short period I felt that I could feel the flow difference. That may sound odd, and maybe it's just me "wanting" it to help, but . . .
Waste Land
Non Multa Sed Multum
Florence, AL
I think it will make a relatively small difference. Nothing major and nothing that I could justify IMHO.
Taking it apart to fix some seals is one thing but porting/epoxing the cases is another.
If you do it let us know what you think before and after.
what kind of engine setup are you running...from what Paul told me, unless your running bigbore or really increasing your CCs it cant help too much. Just good for BBK/strokers, etc
F
Freestyleriverrat
Guest
more case porting pics
Since right now I'm in the process to epoxy a set of cases, I did some research and found that MarineTex, Devcon (all) and PC11 have an upper heat limit of 200 degrees. The longer it is exposed to high levels of heat (even below their limit), these products have a higher fail factor.
As for the A&B epoxy sticks, I've used them in the past to make intake manifold runner wings (Edelbrock Victor Jr.). But only because I needed something to keep shape while it hardens and is the only option. I've found that these putty like epoxies don't impregnate into the opposing metal as well as the liquid based.
Ironically, J.B Weld limit is 500 degrees :biggthumpup:
FYI; for pro builders:
There is a company called Cotronics Corp. (in N.Y) that makes several high temperature epoxies. Their "Duralco 4540" is rated at 500 degrees and looks ideal for these applications. Comes in pints & gallon.
