- Valley Springs, CA
I went from a stock flywheel to a RAD charging flywheel and was amazed. Many choices brother but either way you are supporting the sport and that's all that matters
solas pump? dont know if its making a big differance.but its a think im thinking about but $$$$$$$$$$$Thats plenty ,i take you did not pull the trigger on the solas pump ?
if you are running stock carbs, aftermarket reeds of any kind , do nothing. i put V2s in my sxr a couple different times and pulled them right back out and sold them on ebay. WASTE OF MONEY. the only noticeable difference is your wallet is thinner.
Sucks for you. I put vf3 in my stock SXR along with aftermarket FAs, turned my screws open a bit and noticed a HUGE increase in low end. They were the first two mods I ever did and I'm glad too. Worth it.
False. FA's help a bit on the bottom, but it is not that big of a deal. $250 is spent much better elsewhere.
They have twice as many petals that only have to move 1/2 the distance that stock reeds do at any given rpm. That is called throttle response
