WFO Speedracer
- Alabama
Any kind of plastic that will hold a vacuum will work, on the sides you should be good as you will probably be able to do that part wrinkle free, on the tray that will be a lot more difficult but then its under turf and it won't really matter.The most important thing is to use good quality tape and come up with a good way to secure the vacuum valve to the bag, small vacuum leaks will drive you nut trying to locate them, the links below have a fairly cheap vacuum bagging valve, and a much better valve, buy the more expensive one, trust me its worth it !
https://carbonsales.com/Vacuum-Connection-Suction-Cup-1-4-MPT.html
http://www.aircraftspruce.com/pages/cm/vacuumbagging_valves/vbvacvalve2.php
