VForce 3 Stuffers
RVM
Uruguay
I am trying to install a VF3 kit on my Superjet 701 that has minor modifications (MSD, high flow filters, R&D exhaust sleeve, VF3).
I have a doubt about which of the Stuffers that the Kit brings to install, or not to install any of them, since I see that there is a step that could hinder the flow of gases.
Can anyone give me an opinion on which stuffer to install or the option not to install any of them, what improvement would I get in each case?
Thanks colleagues.
RVM
Uruguay
Utilice los rellenos más grandes. Los que tienen menor área de ingesta.
Gracias por tu sugerencia, debes colocar los que tienen el número 130, que son los más pequeños o con el relleno más grande.
¿Tienes idea de lo que sucede si no colocas ningún relleno cuál sería el resultado?
Gracias
SXIPro
JM781 Big Bore
Gracias
Translation: Thanks for your suggestion, you should place the ones with the number 130, which are the smallest or with the largest filling.
Do you have any idea what happens if you don't put any filling, what would the result be?
Thanks
