speedysprocket
Alex
- Chesapeake, VA
Of what?
all tubes and thru hull fittings are sealed from the inside with epoxy. I never in my life used steel rivets as I buy them by the boxes and are all aluminum (so that's kinda weird)I'm not hating. I don't care who buys what hull. Josh hasn't said anything because he believes it'll just be faster and easier to fix it ourselves. And that hull is about 1 1/2 years old, not two.
I'd like this to be more constructive feed back...
The bond between top and bottom is obviously where it broke in the front. The glue and gel coat over it has cracked a good ways down the bond line on both sides. That's understandable considering the situation.
The "visual carbon" on the inside was just that, visual. All of it under the engine was completely seperated from the hull and peeled right off, and up the sides you can still get a fingernail under it and pry it off.
The carbon exhaust tube had no bonding with the bulkhead, so it leaked like crazy into the tray. The pump shoe was installed with one aluminum rivet and three steel rivets which are obviously rusted. I didn't look at it yet, but Josh said the hole for the rear bow eye has an unsealed gap between top and bottom deck. The tube for the driveshaft doesn't look sealed at the pump tunnel. We had filled the rear of the ski with water (no foam) because he complained it sunk fast, and water came out of every possible hole (with everything bolted in) and some places we couldn't identify. Oh and looks like the plates for the engine mounts are starting to corrode. We don't know how much glass is over them, or if it's just the visual carbon, yet. This has turned into a lot more work than anticipated...
I don't have a picture of the inside. The glass inside on the bottom looks fine, the carbon just had zero bond to it. Here's repair progress, that's all I have now.
View attachment 235453View attachment 235454
It's more than strength issues. From bow to stern, details small and large overlooked.
This is gettin phishey
All right then, no more visual carbon inside of the glass hulls. I'm just gonna throw some paint in there like every one else.
BTW, I have yet to see a hull that does not take on any water in the tray thus the reason I always install versi plugs for the rear section.
See that! I can take negative feedback and turn into solving the problem. That's why I like to hear from other that ride my hulls.
