- Lake Havasu City
Hello, The IJSBA is asking us to help them define some new rules for the ski class. Below I'm adding some notes in Blue to help you understand the possible new rule. Please copy/ paste the below and email it to Info@IJSBA.com PLEASE Forward to to as many friends as possible!!! Voting ends Jan 2nd.
- Shall IJSBA require that Ski Class PWC have the handle pole pivot in front of the engine compartment as a mandatory provision? This is a rule that is not defined in the rule book. Simple and obvious for us, but by voting Yes we can define the dimension and scale for the next OEM. I vote Yes
- Shall IJSBA require that Ski Class PWC have the engine compartment located in front (towards the direction of the bow) of the tray area. This is a rule that is not defined in the rule book. Simple and obvious for us, but by voting Yes we can define the dimension and scale for the next OEM. I vote Yes
- Shall IJSBA require that Ski Class PWC have a mandatory limitation that the ride plate, whether OEM or aftermarket, may not exceed 5 inches (127mm) past the stern edge of the upper deck? This is a rule that is not defined in the rule book for the OEM. By voting Yes we can define the dimension and scale for the next OEM. I vote Yes
- Shall IJSBA require that Ski Class PWC have a mandatory limitation that the ride pump, venture, and steering nozzle combination, whether OEM or aftermarket, may not exceed 5 inches (127mm) past the stern edge of the upper deck? This is a rule that is not defined in the rule book for the OEM. If you add 5" to an SXR it would be the same length as a Belassi B3S (Latest standup to compete). I vote Yes
- Shall IJSBA require that Ski Class PWC, whether OEM, or aftermarket, shall not exceed 97 inches (2.46m) from bumper to the most stern measurement of the PWC (measured by steering nozzle or ride plate, whichever protrudes most)? This is important because the current rule is 10' or 120" or 3.048m, that is to long and it's important that we limit this to the longest production ski to date the Belassi B3S at 96.5". I Vote Yes
- Shall IJSBA require that Ski Class PWC have mandatory flotation material (i.e. foam, inflatable, etc.) in the front and rear of the PWC that consumes 15% of the hull/deck volume? This is a rule that is not defined in the rule book. Simple and obvious for us, but by voting Yes we can define the dimension and scale for the next OEM. I vote Yes
- Shall IJSBA abandon the 8.2.2 provision, in Open Class(es), for Ski Watercraft only, that the aftermarket top deck must be an exact replica of the OEM top deck with no changes to dimension and/or scale? The current rule says we must exactly copy another manufactures product to be legal. This is ludicrous to be forced to "copy" another manufacture for any class. We need to preserve the entry level and "Open" the Open classes. This rule change and the above 1-6 rules will create a positive economic impact to the Standup Open classes, like we see in the freeride and freestyle industry. We will have more options with competitive prices. I vote Yes
- If Item 7 is yes, which of the following language shall be used:
No change in language simply delete the requirement for an exact replica with no change in dimension or scale? Above the new rules create a definition for the dimension and scale. The only change would be a different shape on the top of the ski. This will allow our sport to have a New feel and look. I would use this language.
Change to a silhouette test to compare to a homologated watercraft? Why? Look at the free ride and freestyle ski industry, they all have a different twist but mostly look the same. This rule makes no sense and it's hard to enforce.
Change to resemble a homologated OEM watercraft? Again why? We need to market our exotic possibilities and have the unique look and not a spinoff. NO
Change to resemble the look and shape of a traditional Ski watercraft? Not necessary. This sport needs a new look and feel not the same old thing. NO - Shall IJSBA modify Rule 7.8.3.4 to clearly indicate that aftermarket fuel pumps are allowed in Runabout Limited? Abstain
- Shall IJSBA modify Rule 7.8.3.1 to clearly indicate that tensioners are part of the pulley system allowed in Runabout Limited? Abstain
- Shall IJSBA allow for replacement aftermarket valves in Runabout Stock Class(es)? Abstain
- Shall IJSBA allow for the supercharger shaft to have an additional oil fitting in Stock Class(es) by modifying Rule 6.4.9.? Abstain
- Shall IJSBA allow for the supercharger shaft to have an additional oil fitting in Limited Class(es) by modifying Rule 7.8.2.12.? Abstain
- Shall IJSBA specifically allow a vacuum line to be added to the intake manifold in Runabout Stock Class(es)? Abstain
- Shall IJSBA specifically allow a vacuum line to be added to the intake manifold in Runabout Limited Class(es)? Abstain
- Shall IJSBA prohibit lithium ion batteries in Stock Class(es) unless OEM equipped? I Vote Yes
- Shall IJSBA require Ski PWC in Open and GP Classes to be equipped with a boost pressure regulator? I vote No
- If Item 17 is yes then shall that boost pressure regulator be set to release at:
12 LBS PSI ?
14 LBS PSI?
16 LBS PSI? - Shall IJSBA change Rule 7.8.4.1 so that, in Limited Class(es), Ski type PWC shall have the required boost regulator release at 12 PSI? Ltd class favors the Hydrospace motor, the Ltd Class is suppose to be a budget class between Stock and Open. I vote Yes
- Shall IJSBA change Open Class(es) and GP Class(es), for Ski PWC, so that Open becomes normally aspirated and GP becomes the class that accommodates Ski PWC equipped with turbochargers and superchargers? We have to many classes. We do NOT want to separate our top pro riders. NO
- Shall IJSBA create restrictor plate requirements for Runabout Class(es) to limit the top speed of Runabouts on closed course tracks? Abstain
- Shall IJSBA change the maximum displacement in Runabout Rec Lites Class(es) to 1100cc with the following restrictions: 0-900cc for Runabouts Up to 450lbs and 1100cc for runabouts 720lbs and above? Abstain
- Shall IJSBA modify Runabout Stock Class(es) to require the PWC to be entirely OEM under the seat? Abstain
- If item 23 is No, are there other variations of allowances to remove?
- If item 24 is Yes, what is the implementation time for such a change?
- Shall IJSBA modify Rule 8.2.2 to allow an additional two inches in widening of the Ski’s standing tray area for specific models with a narrow standing area? Only in Open class no for all other classes
- Shall IJSBA modify Rule 6.4.5 to change “Additional cooling supply lines may be added to water inlet covers that are removable from the engine block.” To “ Water inlet covers that are removable from the engine block may be modified or aftermarket.”? Abstain
- Shall IJSBA increase Vintage Ski displacement to 800cc? NO
- Shall IJSBA allow Ski Stock Class(es) to have the provisions of boring the steering nozzle and/or cross model updating/backdating steering nozzles from the same brand Ski? NO
- Shall Veterans Runabout Class(es) switch from Limited Class Rules to Stock Class Rules for those Runabouts equipped with superchargers or turbochargers? Abstain
- Shall IJSBA modify the Runabout Normally Aspirated Class(es) so that Two Stroke powered PWC are scored separately from Four Stroke powered PWC? Abstain
- Shall IJSBA modify Rules 6.6.3, 7.5.1, and 7.8.3.4 so that direction is given on how to manage any fuel return line changes? Abstain
- Shall IJSBA add language to Rule 12.4.2 to specify penalties for missing a log jump and any exceptions to those penalties? YES
- Shall IJSBA extend larger displacement provisions to Open and Limited Ski Class(es) so long as proper restrictions are in place to ensure no advantage in performance over established displacements? YES
