- Zeeland Mi
2006 Wamiltons Molded Superjet
$6750
Hull: Carbon/Kevlar reinforced, Dual exhaust, dual scupper with versaplug max, dual 500 bilge with handlebar switch, Wamiltons internal fill tank, new couch mounts, x metal pole ,pinch bolts, and bracket, UMI steering , Wamiltons finger throttle,worx 228 grate, Wamiltons extended ride plate, superfreak footholds, 26mm plush underpad, kicker, and fresh turf summer 2019.
Motor: 760 64x even 175/175 compression, ada girdled head (38cc domes), 61x stator/ lightened oem flywheel, MSD enhancer, MSD ignition coil, v force 2 carbon reeds, dual 38s, b pipe mod chamber, ported manifold by Wamiltons, oem rn waterbox ada lightweight couplers.
Pump: 144 oem pump, stubby pump cone, bored reduction nozzle, Solas prop unknown pitch.
Ski is RTR, perfectly tuned and absolutely rips! Hull was painted and signed by Wamiltons and shows some wear and tear on bottom deck from beaching, nothing structural. Motor was built this year. Test rides with cash in hand, this beast does not disappoint!
Clean title and MI registration till 2022.
Will consider shipping at buyer expense.
Will consider trading with cash in my end for a Krash 50cal or Tigercraft Aquabot V2 nothing else!
$6750
