- Grand Rapids
Who has tried these? What size piston should you run 84-87? Also do they hit hard? Are they reliable?
This setup can run very good, but it's a KIT that a pro engine builder will have to assemble. It needs to be ported and requires machining that most people cannot do at home. FWIW just buy a Dasa SS850 or Team Scream ss865/900. You'll spend less in the long run.
Are you talking about the ADA cylinder kit? Cuz Watcon BB cylinders (which the OP is asking about) are not "required to be assembled by a pro-engine builder".
And if you are talking about the ADA kit, if you go with the right builder I guarantee you will not spend more money in the long run compared to the DASA or TS.Far less, actually.
