- Fort Worth, Texas
So I just installed the new php, im running a carbon RRP wet pipe... I can not for the life of me keep from finding water droplets on the raves after a ride... I've made sure it's not coming thru the carbs... they are not wet and i have prefilters on them now just to make sure... no water being thrown up either... I checked all that on the trailer... I thought it may be the exhaust just running back into the chambers when I come in nose kinda high, but the issue gets worse the longer i ride (oil is milky after a long ride instead of just some droplets on the raves) I did notice that the manifold from RRP seems to not match up well to the exhaust gasket making me think maybe it's spraying in at that point... either way I can't figure it out... I've installed a flow control valve at the water box also just cut down the water there, and I also noticed the RRP water injection fitting is just an open tube after the jet and not a spray bar by any means...
