And here is the correct link to the ugly exhaust flap I use. I'm designing an internal one so you don't see it.
http://www.cpperformance.com/vsearch.aspx?SearchTerm=810 EG 300#Filter=[EntityIDs=@(1446)@*Name=810[/URL]
I fount a temporary solution until my new style waterbox is finished. The flap stops the water from coming back in.im starting to think it's the waterbox being so small, or the excess water from the spray bar.... after shut down, if you sink the tray trying to get on and get started it will back fill the motor with water... not much but too much for me... I noticed many other waterboxes are much taller than this small RRP. RRP won't return emails when I asked about this.. only when I asked about install (which i was told to use NO jets in spray bar, and no flow control or jets on waterbox, so that was Def. an issue at first).. i have jetted both now..
I already have one installed on it lolI fount a temporary solution until my new style waterbox is finished. The flap stops the water from coming back in.
http://www.hardin-marine.com/p-13182-2-12quot-to-3quot-id-external-flapper.aspx
I don't have any issues.. its when someone else tries to ride it.... i don't sink the back.... I will raise that box as high as I can, maybe that will also help...Your having the same issue I had, deep water reboard gets water in.. I raised water box 3.5 inch above the built in battery tray... If you want to know how much to raise the box put the ski in the lake with the hood off and transfer the lake water level outside the hull at your stinger to the inside of your engine bay at the pipe stinger and see how much more you need to get the stinger of your pipe above lake level.
Exit: the other thing I do and i learned it here on the X is to side start the ski. Now with the water box plenty high I can deep water re-board up the tray with engine off without issue... But I now also have started to tilt the ski on the exhaust side till the start button is near the water and start the engine then climb aboard...
