Water in fuel
dbrutherford
Parts Whore
Fairmont, WV
meatball said:
Just saw a pic of a fuel tank (forget where) and instead of running the water seperator setup, he just cut the line down very short off the fuel tank nipple, put the one-way on and then a very small one inch nub of fuel line off that. Looks like it would work fine.
This is exactly what you need to do!
The check valve prevents gas from going back into you engine compartment. The no water seperator prevents you ski from blowing up!
On my old 95 X2 the water seperator filled up and allowed a bunch of water into my gas. The ski ran ok until it busted the rod on the rear! It even kept running on the front cylinder. Anyways ditch the water seperator or atleast drill some holes in the bottom of it! That should fix it.
DBR
The other Alex
(Jetdude)
Lake St. Clair--
Ive sanken many a ski, and none of them had any problems with water getting in the fuel with the stock vent set up. On my new SJ, the OEM water seperator was done away with, with the tube and bulb right on the tank, when the ski went down, the tank filled completely up with water. I would leave the water seperator on and just unscrew it...
meatball
User Title Unavailable
Maryland
The only way water would go into the tank with that setup is if it sinks completely with it right side up. Even then, your going to have to do some serious work to it and pumping out the gas is a given. If it just rolls over, no water will enter the tank, because there will be no vacuum upwards unless you rev the engine for a couple seconds, even then its minimal. If its flipped upside down, then the air bubble on top prevents the water from entering because the pressure cant be released, even if the ski completely sinks underwater.
After thinking, no water will get in if it sinks right side up either, because there will be no vacuum, and air cant escape to allow water in. I dont see your logic. With the stock OEM setup with that length of tube, and the engine running as it usually is when subbing, etc. Water enters through the bulb on the handle-pole, with the suction created by the running motor, the seperator fills up, and then dumps into the tank. With no seperator, the nipple and one-way never touch water, and only when the ski sinks or flips, and even then, without a motor running to create suction, there will be no way for water to enter through that line.
No water will get in with a sunken ski and the OEM setup, because there is no suction is produced, and the one-way doesnt allow pressure out. The problem is when ski is in motion and subs and fountains and such.
The ball thing at the end of my vent hose is missing.Got one orderd put they are back ordered.Think I'm goin to try and put that on and leave every thing stock and see how that does.Seen Pancake Pete's and Pauls ski just has a short hose to the one way valve and then a piece of hose coiled around about 4 or 5 times and the end is in the engine compartment.If the stock set up still doesn't work was thinkin of doin that and just put the ball at the end of the coiled up hose in the engine compartment.Funny thing is I never had this problem till I put the 44s on.I'm pushin alot harder now then I did when I had the 38s on too.Spend alot more time up side down and under the water.
