JetPilot1970
Work at Sea-Doo Factory !
- Quebec, Canada
I'm doing an overall maintenance on my '99 SxiPro. I removed the pump housing to check bearings and impeller. When I removed the cone it was filled with water... Also when I removed the impeller shaft, the pump housing was also filled with water... Under pressure.
There where no trace of rust or bearing problems. I'm just concern about it.
- Is it normal ?
- What can I do ?
Thank you
- Is it normal ?
- What can I do ?
Thank you
