SkiDiggity
formerly kawirider142
Maniac sells the real tool. Do you know how to work on carbs? If not then don't waste 40$ on it. Any small pump works. Bicycle pump works.. Cut off the end . Keep the end on if you buy 2 rim valve stems. Drill a hole and pull the tire stem through the oil block off. Also works for e box. Buy a spare cap from maniac for 6$ and do the same thing to test those. 10psi is all you need
Oh boy this has me all kinds of nervous. I do not have the best of luck when it comes to stuff like this hahah
