SXR Water Lines Routing for Factory Wet Pipe & ADA Girdle Head
Got my Factory wet pipe installed and my new ADA girdled head with dual water outlets. I was running the water lines and have a few questions. The two lines coming from the back of the boat I have the Left line going to the Factory Pipe manifold. The line to the right I have going to the head pipe on the factory pipe. The line from the bottom of the head pipe I have going to the rear water outlet on the head. The line that is going overboard I have a T installed the line going towards the back of the boat do I ... T... that into the top of the head pipe? The line coming off the stinger should that go to the bottom of the T that is going overboard? And then what about the water line coming off the front of the head where should that go?
Thanks
Idaho
If running dual cooling. One water supply line goes to the exhaust manifold. Both lines from the head go overboard. The second incoming line goes to head pipe (top or bottom). Output of head pipe then goes to T. One goes overboard and other goes to stinger on chamber.
If running single cooling. Incoming line goes to exhaust manifold. First output from head goes overboard. Second goes to head pipe (top or bottom). Head pipe then goes to T. One goes overboard the other to chamber stinger
On a stock 800 SXR there are two water lines coming into the boat on the back wall of the boat on either side of the shaft. Is the one to the left water coming in and the one on the right water going overboard out the pump?
