Hey guys,
I'm wondering about this idea I want to try. This probably have been done before anyway. In the picture below, The line A is the water-out line coming out the headpipe and line B is the water-in line for the manifold. I want to take out the B line so I can put the automatic pump there. I can change the line A to a water-in line if I switch the hose from the fitting A for fitting B in the nozzle pump. I can install another pisser next to the other pisser on the side of the hull and run the water out from the headpipe instead of Line A. I can get the line B plug-in to keep the water from leaking inside. Will that works?
Thanks,
Tyler
Thanks,
Tyler
