BombThreat
'Diggity
- Johnstown, NY
I wanted to get your guys suggestions before I install my dry pipe (again).
A little back-story is I installed the dry pipe about 2 months ago and 3 tanks later I deto'd my front piston. Never really could pin point why exactly. But I returned the ski to a stock pipe so I could have something reliable again.
I tapped the pump for dual cooling and used the water dump tube that goes through the hull to make it easier. What do you guys think of the way I had the cooling lines before? Should I set them up differently this time? Maybe that was the culprit for the front piston deto? Although the engine did have alot of hours on it before too... Also Im running one of those old vilder charging flywheels, I guess they have a 5 degree advance built in.. So I did not use the heat sensor loop from factory pipe.
