Waterbox for Rickter Edge (b pipe)
Wbox fitting is pluged. Water is running only through the stinger. I run limited chamber. Power and throttle response are scary in the surf. Stock wbox was what was holding all the power before. Huge improvement with the RRP
Are you feeding water into the waterbox via the fitting on the waterbox itself or just plugging that and using the stinger on the b-pipe to feed the waterbox?
tntsuperjet
Georgetown ca
If you have a problem with the stock water box holding any water inside more then a 1/3 of a cup there a problem with your setup.
As it should evacuate all water in one full throttle blurp over 1 second long.
I would say the water is coming back up from exhaust routing from the rear .
But with engine running there can't be more then a few ounces holding in the bottom.
The head pipe on a b pipe will drain into water box when you shut it off and make it seem as if it's holding water.
My h2o box with a B pipe is very loud. Before I added a hose to direct the outlet downwards towards the water, it would occasionaly hurt my ears. But, my long exhaust hose is an aluminum tube with not much hose so I'd assume that amplifies it..
I am having issues with my neighbors complaining about my exhust being too loud... what kind of hose did you add to direct your exhust down?
