ThanxI only have experience with the OEM box and modifying OEM boxes.
Saw this video today
Verstuurd vanaf mijn SM-G920F met Tapatalk
If I loose just little bit of speed/power that is no reason why don't do it... It is funny here on forum is two "camps" of people - some of them is for mod and the second half don't.
Maybe I try it through weekend if have enough time and then can write results. Now I must figure how to take waterbox out, because what I read, it is not easy way.. Thanx
Today somebody told me better way to mod the waterbox, is not drilling the holes, just put everything out from there... What do you think?Thank you for goodwill.
Ok, thanks for the reply. I will just cut tubes in waterbox and drill holes. Is that right?I think thats better but....if every bad thing comes together you'll engine wil take water if engine is not running...ore you'll stop engine on the water with you on it, it will fill up your engine to...and i think thats its getting way to loud....just drill holes...
@aqualocos do you have expriences with how to remove the tank? It is necessary to remome or move engine? Cant move the tank because of the exaust - wet factory pipe...I think thats better but....if every bad thing comes together you'll engine wil take water if engine is not running...ore you'll stop engine on the water with you on it, it will fill up your engine to...and i think thats its getting way to loud....just drill holes...
