- s florida
I want to share with everybody this nice little custom build I just finished for a client in China. Here is the list of components:
Hull:
-78 LBS custom WF BF hull with custom lime green gelcoat
-WF hood and nose piece
-WF custom carbon ride plate
-WF custom carbon chinpad
-x-metal -2 handlepole, throttle, bars and turnplate
- x-metal dual scuppers (in pump area)
- custom rear side exhaust
-custom WF hydroturf
- 9 liter custom go kart tank (thanks Hunter!)
- WF custom engine plate with front battery mounting area
Engine:
- 6mm stroker crank
- 6mm Lamey Np cylinder with freestyle porting
- 86mm Riva flat top pistons
- ADA girdle head with 26cc domes (205 psi)
- machined and ported 62t cases
- stock electronics with MSD enhanser (requested by the customer )
- factory b pipe with jetworks flow valve
- dual cooling
- Dual Riva 48mm Powerbombs carburators
- X-metal waterbox with front exhaust
Pump:
- skat track 140mm 12 vein set back magnum pump with 15/21 prop
- Riva intake grate
- Virgin waterworks pulley pull trim system
- protec steering nozzle
got to ride this beast the other day and WOW:arms::Banane09:
Hull:
Engine:
- 6mm stroker crank
- dual cooling
Pump:
- Riva intake grate
