- Tuscaloosa, AL
The impeller is not warped, it was mentioned in this thread or one of your others. The stainless liner and alum housing will suffer from galvonic corrosion. This will cause the stainless liner to "Swell". If it is not bad you can take a grinder to it and clearance it. I have had to do this. At some point you will have to replace it. As far as removing the prop, you will need the spline tool to hold onto the end of the drive shaft. and a wrench on the hex portion of the prop. The prop threads are opposide or reverse threaded. So, if the you will either turn the spline tool counter clockwise holding the prop in place with a wrench, or turn the prop clockwise if the spline tool is in a vice....... I use a long cheater bar for removing props.
