waveblaster wiring driagram
hi help needed i pulled the ignition box apart dick moove i now on my part ..now there wires every where on my wave blaster ....does any1 have or know where i could find a shematic wiring driagram for the 95 wb thanx :wizard:
ok now this only get worse .......i pilled my 2002 superjet wiring box apart to copy the wiring .....umm looks like i may now need a wiring diagram for the superjet to ....no flaming please i know
Dustin Mustangs
uʍop ǝpıs dn
Holland, MI
Bada Boom!
:beerchug:
DCRocks
Wavejunkies
Washington DC
Most of the wires will match in colors between the wires from the start/stop switch and the stator, and the CDI. As well as the coil and starter relay and the CDI.
The temp sensor is removed in my blaster, and if this is the same in yours, you will end up with 2 extra wires in your CDI that do not get connected, just secured.
The superjet wiring should be pretty much the same as the blaster.
I find the first picture to be by far the most helpful, and the one you should concentrate on, when trying to reconnect everything.
