Freestyle WCF visual carbon fiber Vision 3G
waterfreak
I had a vision!
Vendor Account
s florida
Well, here it is finally, our first carbon Vision 3G. We took a long time experimenting and perfecting the infusion technique with the help of 3G composites inc. here in S FL. This hull is resin infused using 19.7oz carbon and some "special" infusion resin.
Once finished, we will add decals and spray some UV clear for the perfect carbon look:cool:
hhh
That looks so nice steve should be one awesome hull finished. Are you doing visual on top as well? I hope at least :)
waterfreak
I had a vision!
Vendor Account
s florida
yes, the entire hull will be visual carbon. This was the only way I wanted to do a carbon vision and without infusing, it would of been very difficult
vwking
Banned
Folsom Ca
I must say that is a BEAUTIFUL visual carbon hull. I as well understand how to work with carbon. Resin infusion setups as well as pre-impregnated process and a normal wet layup. Vacuum bagging is were 90% of people screw up. So resin infusion what a tricky long headache figuring out how to do it proper. Must say that the hull looks 100% beautiful hands down keep up the excellent work!
INDebtSJ
Having a VISION!
Ga
I am planning on selling them for $7995. That will be completly done with UV clear+ graphics+ ride shoe +epic scupper and turfed
The weight is estimated to be around 60 lbs .
Ditch the epic scupper. Flipsides scupper is swollen and rusty. Put the kind that you put in mine.
rubbertoe
X-H20 certified
San Diego
WCF work is quality ,top notch ! i think if there is anything i would ask Steve about customizing if i were considering this hull for 8k,would be a little rocker in the rear
