Custom/Hybrid WDK ROK guys. Need help with cables.
Draggingto
No Clue
Brooklyn MI
I've got a Rok that I'm putting together. Pretty much taking everything I can out of my RN. Well I got to the cables and both the throttle and steering are both to short. I'm running a full length RRP pole and a quick turn plate that is stock length.
I'm trying to figure out what cables are available and will work best. Lengths or what they came out of.
Also my exhaust tube is about 2in to short. Did anyone else have anything like that or what did you use.
Thanks, Bryan
I think Square nose cable may be longer, I may have one, if that won't work blowsion sells a long one. May have to get a long exhaust hose from a sit down and cut it down.
swapmeet
Brotastic
Arlington TX
On the exhaust tube, buy a piece of aluminum pipe with the OD that matches the ID of the hose and make a spacer. Not glamorous but it'll work.
Draggingto
No Clue
Brooklyn MI
That would be awesome if you do. Let me know and I will come get it ASAP. In my research that is what I have seen is a lot of guys used the SN cables. Both steering and throttle. What one do you think you have?
That is exactly what I was thinking of doing. Thanks for the confirmation.
Draggingto
No Clue
Brooklyn MI
Well, if you wanted to do it the right way......
Yeah I understand that. But i think it will be okay for right now. Ill end up buying a new hose soon. But money is getting short after buying everything thing I have so far and making the trip to florida to get it lol.
I have a new throttle cable from jetmaniac that was too long for my freak, and not sure what the steering cable was from a vxr I believe, that was also too long, come grab them and see if they work.
