Vumad
Super Hero, with a cape!
- St. Pete, FL
I designed this waterbox and had it built. I blew it apart almost immediately.
It uses .060 aluminum. It has baffels but not going to explain how they are setup. It's possible they create too much back pressure but the boat made good power for the few moments before it started leaking exhaust. I ran it with the hood off and had good power but then completely blew it apart. You can't see it but the long weld on the right is split about 4".
Before I go to the shop that built it, I'd like some comments about the quality of the welds. Or if it's more likely that the metal was too thin or the back pressure was too high.
Personally, I want to blame the welds, but I'm not very experienced with metal working.
