- Cadilac, mi
You guys are probably sick of me by now but I just cant figure this damn thing out. getting no spark, tested the start/stop and also bipassed it but isnt the problem. OHM tested the cdi all checks out fine. Thought i found the problem when i noticed i was only getting an OHM reading through the spark plug wires when they were bent a certain way so i replaced the one bad plug wire where it was bad at the head tried it again and still no spark. next was to voltage test the stator while turning it over, tried it but i dont have a great multi tester and apparently to test it right i need one that captures peak voltage? anyways i tried the wires the dealer told me too with the tester i do have and got it to bump on the meter but no where near how high it was suppose too but that might be because i wasnt using a peak reading voltage meter. i dont know where to continue to now, im at a loss, nothing seems to be bad!!!
