The ski is pretty much done I will post up more pics after havasu.
Most of the assembly and plumbing was done by me.
WDK ROK hull
WDK rev holds with enclosures
WDK manifold & wet pipe (new version very nice!)
WDK head kit with 33cc domes
WDK lowered handle pole mount
WDK steering stop
WDK Ported 66e cases
WDK/Wiseco 87mm pistons
TWISTER cranks lightened crank -2lbs welded balanced
Bored and re-nicasild 66v cylinders
RRP billet pole
RRP 3" riser bars
RRP steering
LSP "shur stop" S/S switches
Seadoo style lanyard mounted under chin pad
O.D.I Yetty grips
THRUST 12" steering cable
Stock ignition/flywheel
Stock reeds
COLD Fusion couplers
8.5L Kart tank
Blue printed 144 pump
SKAT/IMPROS 15/20 3mm set back c75 hub swirl W/kick on the edge impeller
RIVA power valves which are not installed due to tunning.
I plan on picking up a 144 mag pump at WF, Hopefuly I can get a good deal there.
WDK ROK hull
WDK steering stop
RRP billet pole
RRP 3" riser bars
RRP steering
O.D.I Yetty grips
Stock reeds
8.5L Kart tank
