Damn, does everyone have a vacuum pump setup at their house...lol. Or is this just the natural progression for the tinkering type?
I built this vac setup for very reasonable and scored a NEW in box high CFM pump off ebay for stupid cheap. Its auto cycling and adjustable. It did had a small leak on one of the resin catches, but it still made some kick ass rideplates and I have done hull reinforcements with it. I made some ultra THIN infusion rideplates that were strong as a MFer!
Thats a great tutorial. Love how the resin flows through the part.Since I love to share...
This is the setup I am going to attempt to make. Need the nifty fittings they have though. The pump looks like the cheaper 120$ HF model. The rest of the parts look like they can be found at the hardware store. I bet if I try I can just rig up the bag connector fittings some how.
How do you reinforce a hull with the vaccuum? Do you bag the whole ski?
Great info. Good video tutorial as well.
This place has come interesting bagging materials. One is a couple bagging tubes from 30-36" that could be used to slip over an entire top or bottom deck when flanges are not available to seal to. You'd only have the two open ends to seal.
They also have a stretchable bagging material, no worries bout leaving extra bag to prevent bridging an having to re-position the bag. Here is a direct link to the bagging section of their site.
Another trick a friend put me on to was using plastic mesh instead of bleeder cloth, you will pull more resin into the trap of course but you can actually watch the resin being pulled through the channels, if you are using polyester or vinyl ester you just pull the mesh out when you are done and it leaves a nice surface for secondary bonding like peel ply, if you are using epoxy resin it becomes a permanent part of the layup. So using this you can eleminate the peel ply and the bleeder cloth, two less things to have to worry about.I am using the knitted mesh 40%
http://www.mcmaster.com/#plastic-mesh-screens/=g0p3x7
Hmm, but won't that essentially leave voids in between the mesh that will hold excess resin? I know there are some smooth peel ply materials out there that leave a better finish, but finish doesn't really matter too much to me, anything will look better than the chop gun finish the factory SXR has.
Also, any benefits to using a core material in build up such as this Coremat?
Ok I never really understood the catch can thing. What's the point of it? I understand its purpose but why is it needed in the first place unless you're doing some kind of resin infusion? The bleeder and breather cloth should work like a champ unless you poured buckets of resin on everything. Should always put an extra layer of breather under your vacuum port anyway.
This is the first I've ever heard of mesh screens. Bleeder and breather are cheaper than the mesh screen and the bleeder cloth is finely textured as well so when it's pulled off, the area is ready for secondary bonding as well. Does the screen allow uniform pressure like the breather cloth does? I'm confused with the benefit.
Not trying to be a jerk, just looking for clarification.
Catch can for a wet layup could be a good idea for beginners that might have more resin than the bleeder cloth can hold. Just safety to make sure NOTHING gets in your pump.
Also, I didn't think that Coremat was supposed to absorb much at all. I'll have to read up on it, might be a decent idea in something like Tubbies where you need to build thickness. It's supposed to be way lighter than something like glass mat, roving, or 1708 when wetted out.
