Between the hammering sound that did not exist prior to porting and learning later on from Waxhead on a forum somewhere...can't remember where now though lol...he mentioned the shape of the Race Logic templates had issues with snagging rings. If you recall how they looked, they were rather wide at the bottom and quickly narrowed at the top. With a bit too much chamfer the rings would squeeze out of the ring grooves just enough to be too much. And like in the photos on this thread, you could see where the rings were snapping back in at the top of the port. The bottom however when allowing the ring to go oblonged squeezing into the port and suddenly jarring back into the ring groove is where the stress on the crown starts going to work. I believe that the crown blew off on the down stroke sending the pieces on top of the piston causing the pitted damage. Mine had crumble cake all over the top when I tore it down. When I re-ported, I used your template that I won in "guess how many I have left and you get a freebie" challenge you had last year. Point of interest, your templates are very well done.
