95 YAMAHA WAVEBLASTER-1
DESIGNED AND BUILT FOR THE SURF.
COMPETITION READY!!!
EVERYTHING ON THIS SKI IS BRAND NEW WITH ONLY 4 HOURS ON THE MOTOR.IN 2008 I STRIPPED THE SKI COMPLETELY DOWN AND HAD THE BOTTOM RESURFACED AND GEL-COATED.THE TOP HALF WAS SANDED AND SPRAYED WITH A 2-STAGED EPOXY, TOP AND BOTTOM ARE PURE WHITE. THE SKI WAS COMPLETED IN OCT-2009 IN LAS VEGAS,NV I NOW LIVE IN DALLAS,TX. INCLUDED IN THE PRICE WILL BE THE BLASTER WITH TITLE, SHOP DOLLY,THE BEACH BOX AND ALL THE EXTRA RACING PARTS FOR DIFFERENT RIDING PLACES AND CONDITIONS.
62T CASES
760 JUGS/STOCK BORE
NEW OEM CRANK
NEW OEM BENDIX
NEW OEM STARTER
NEW PRO-X PISTONS/RINGS
61X FLYWHEEL-LIGHTENED/GROUP-K
61X STATOR
OIL INJECTOR BLOCK OFF PLATE
NEW BILLET DRIVE COUPLER
NEW CARBON-TECH REEDS-LT
NEW ANGLED REED SPACER
DUAL 44mm MIKUNI CARBS
DUAL 38mm MIKUNI CARBS/TAPER BORED
760 INTAKE MANIFOLD/PORT MATCHED
62T INTAKE MANIFOLD/PORT MATCHED
BLOWSION AIR FILTERS W/SOCKS
ADA BILLET HEAD W/GIRDLE KIT
DOMES 38cc 2 EACH
DOMES 35cc 2 EACH
FACTORY MOD PIPE W/PORT MATCHED EX-MANIFOLD ALL POLISHED
EXHAUST RESINATOR W/WATER FITTING ALL POLISHED
MICRO TOUCH WATER INJECTION
DUAL COOLING
WATER STRAINER
CUSTOM BUILT AND FITTED EXHAUST PIPE FOR THE BLOWSION SIDE EXHAUST
MSD ENHANCER
NEW COIL
NEW BOOTS
DUAL 500 GPH BILGE PUMPS ON/OFF
DUAL SCUPPER BALL VALVE DRAIN
NEW POWER SOURCE SEALED BATTERY
NEW ODI GRIPS
NEW UMI BARS
NEW UMI FINGER THROTTLE
NEW STOP/START SWITCH
NEW PRIMER
NEW FUEL SWITCH
NEW GAS SHOCK FOR HOOD
NEW FIRE EXTINGUISHER
NEW YAMAHA FUEL CAP
NEW OEM FRONT BUMPER
NEW HYDRO TURF MAT KIT
NEW HYDRO TURF SEAT
NEW DAKINE X-LACES FOOT STRAPS
ANCHOR BAG
NEW WORXS INTAKE GRATE
NEW WORXS RIDE PLATE
NEW BLOWSION CARBON FIBER D-CUT RIDE PLATE
NEW YAMAHA PRO SIERIES RIDE PLATE
BORED COMPRESSION NOZZLE 85mm
NEW GO-PRO HD WIDE CAM
NEW TINY TACH/HOUR METER
NEW STAINLESS STEEL SEAT HOLDERS
NEW WATER BYPASS FITTINGS
NEW FLOW CONTROL VALVE
ONLY THE CASES AND THE INTAKE MANIFOLDS HAVE BEED EPOXIED AND PORTED. THE EXHAUST PORTS HAVE NOT BEEN LIFTED.CURRENTLY RUNNING 100-104 OCTANE W/CASTROL 927 PRE-MIX. THERE IS NO PROP FOR THIS SKI DUE TO TESTING ALL TYPES OF PROPS. THE PROP IT WILL NEED IS A HOOKER 9/15 FROM IMPROS OR A NEWER SUPER JET STOCK PROP. I ALSO HAVE ALL THE PHOTOS OF THE BUILD FROM START TO FINISH. COMES WITH EVERYTHING BUT THE MECHANIC.
$4500.00
