Aircraftsalz
Thrust built Dasa Power
- Off site
Run it (32:1) 4 oz of oil to 1 gallon of gas. Put it back together & ride it!
Wouldn't richening the oil/fuel mixture lean out the air/fuel mixture going to the engine?
Yes it would...50:1 with a good oil sounds better to me.
What type of grease are you talking about? I was going to put anti-seize on the bolts and dielectric grease on the electrical connections, is that good or is there something else? Got new o-rings on order so I'll replace them for my piece of mind. I'll also make sure the mating surface is good and clean.
Generally when someone talks about lean/rich conditions they are talking about air/fuel and this can be changed by adjusting the carb adjustment screws along with other things that I won't go into. You can slightly modify air/fuel mixture by adding more or less oil to accomodate a rich or lean condition in your engine but it is not the way to fix a problem. Do some reading on carb tuning. You may also want to read the mikuni SBN tuning manual.
