If it was fuel related you would have noticed fuel dripping out of the high speed circuit and it would load up very easily. If it was not getting fuel into the carb it would most definitely have a hesitation bog. I have a feeling this was a used ignition and it is new to you. Even if the third channel does not fix the problem you know the second one works. Run that on the front cylinder and see what happens.
