What is the best Rec Freestyle Carb Set up?
most of us are not here to argue,Id just rather if someone posts about something that could change your setup it would be from personal or close "in YOUR ride group" experience. We have learned a shiz load in our group,everyone has something diff in their setup and we all get to ride it.If im wrong on this next setup ill be the first to admit it here,and move on to the next solution.My pulsing fuel issue is all that worries me,but im switching to a remote fuel pump at the same time to make sure
Scorn800
Ride for life
North NJ
The only aftermarket carb's I've ever used is Novi. I used dual 48 maxflow's on dry piped limited sxr. I put these on afterrunning stock modded carbs. I called Tim for the jetting info. The boat pulls alot harder with the Novi's. Their worth the money.
Being a "bolt-on junky" will not produce a better running boat without having plan for a total package. Once you start with something you know that works you then try to approve upon it by tuning certain parts.
Oregon
i herd novi was working on a set of carbs i cant remember the specs paul at LPW knows. Red top carbs are pretty freakn awsome for low end snap, but good luck finding a set
