What is the max bore of oem 760 cyl ?
#ZERO
Beach Bum
Florida - U.S.A.
Wiseco recommends big bore sleeves on their 85.5mm and larger pistons.
The outside diameter of a 760 sleeve is only 88.78mm at the bottom and big bore sleeves range from 90mm to 91mm.
If you bore a 760 sleeve up to 86.5mm it's going to be 1.14mm thick at the bottom and that's only if the bore is centered correctly.
