WaveDemon
Not Dead - Notable Member
- Hell, Florida
what mods are NEEDED for freeride 66e?
I want my 66e to be a better motor than my current DIY big bore (61x case with 86mm 760 cylinder) from the beginning and mod from there. Getting your hands on this motor and then getting it to work/fit in a SJ is expensive (to me). I need the motor mods to be as cheap as possible to get this project going. I’ll mod more later as funds allow.
To keep this project cheap I’m going to adapt a b-pipe to fit the 66e, make my own upright mounting kit, use the stock sj tank and 144 pump with tbm cone and mag impellors (most likely)
I’ve got a stock 66e with a new top end on it. I understand that this motor isn’t set up for low end from the factory.
I’m trying to avoid new pistons/sleeves/nikasil plating/aftermarket ignition
What I’m thinking of doing to keep things cheap (machine work is cheap for me right now):
Cut stock head for 93 octane gas.
And/or
Lower port timing by milling the bottom of the cylinders and making reliefs in the stock head.
or
Look for 2 good used gp1300 cylinders and pistons
I’m open to port timing advice, I’ve got a single gp1300r cylinder that needs a bore that I can take port timing from as a guide if not.
Any advise or words of warning from you guys?
And/or
or
