kkwedell
x-h20.com
- Walnut Creek
I just take a gallon of pennzoil and mix 16 oz of redline in it. Seems to work just as good as running straight redline with keeping the cost down.
Like the title says. I want to see what everyone is running and maybe give me a reason why you run it. I'm sure we will get some funny answers.
This year I switched to walmart oil which is $12 a gallon. I wanted to see if oil really made a difference, so far the only difference I can tell is the smell of it when it burns. Ski still makes good compression and it didn't blow up yet. I used to run maxima K2 but it felt like a waste of money. Speaking of money now that I have parted out a few skis I have drained the oil tanks on them and burnt that oil. I can't complain about free oil, you just need to make sure there isn't any water in it.
For those of you who didn't feel like reading that here is the oii I use and why I use it.
Walmart oil - Because it's cheap $12/gal
Oil from skis I parted out - because it's free
So what do you run and why did you choose it?
From what i have heard from a friend. Is that his uncle who works for one of the companies that sells high performance oils (i.e redline) i forget the exact one. Was told from their testing supertech aka walmart 2 stroke oil was the best oil for non powervalve motors.
Since then i have been running it. Works good, smells good, looks good.
amsoil... mostly because I'm a dealer...
Walmart, any generic TCW3 isoil.
I was running generics. Walmart, Westmarine, etc. I had horrible water ingestion problems. I started thinking about this blue froth I had on stuff all the time. One of the guys in the group on a B1 had similar problems in the surf. He found a local place that wholesales Merc Quicksilver (fill you 1ga from a 55ga, $20/ga), so he gave it a shot. No more water ingestion issues. I switched, my issues vastly improved (X2 always has ingestion issues).
So, of course, experiment to back up a claim...
Take yourgeneric oil. Put about 1" worth in a glass jar. Put the next 5-6" as water (old spagitti jars work good). Shake well. Quicksilver immediately beads up like cooking oil. Generics turn the water blue, froth and take hours to separate. Oil the mixes with water? What the crap?
We have found a place local that sells amzoil for $28/ga wholesale, so I may be switching over to that once I burn through my stockpile of quicksilver, now that I can afford a little better oil.
I'm sure a few of those threads OCD linked have similar info.
Moral of the story, buy the best oil you can afford, but don't buy the cheapest available even if it's all you can afford.
Never even considered water ingestion as a reason for running one oil or another. I'd like to do that experiment just to see but I still dont understand why getting water in your carbs will make any difference of how it reacts with the oil.
anything TCW-3
I prefer quicksilver, been using it for year
Klotz, it's a good oil about $40 a gallon and it smells like candy!
I think it's crazy how many people run cheap oil. I figured most people would be running the expensive stuff.
I'd still like to hear some reasons why some people choose the expensive stuff over the cheap stuff. I can't see any real proof that shows how one oil is better than another. Maybe some burn cleaner or smell good but that's about it. That's pretty much why I started this thread. How do you justify paying the extra $40 a gallon over the cheap oil? What is it really doing for you, or what do you think it's doing for you.
