ANT
Just ride
- Sea Isle City, NJ
Why are you going with a 148mm? The stock pump properly set up is sufficient for that motor...
I'm beginning to wonder that myself. I was thinking because of some,of,the good deals floating around right now on the bigger pumps that if I could turn them with my motor it wouldn't be a big setback.
But I'm starting to think I should wait until I've got a bigger driveline to get a bigger pump.
Sent from my VS980 4G using Tapatalk 2
I think it all depends on your upgrade timeline. Will you upgrade motor fairly soon?
If you have a lightweight a/m hull, then it will be easier to turn the 148 prop off the bottom. You need a 6 or 7 on the bottom and a relatively short top pitch as well. You can also space the prop forward to increase slip and let it spool up easier.
