Ok so a have a 90 sn superjet. It has a 61x in it all done up. It will run great one day and rip your arms off. The next day it will run like . The next day it just wont start. I check for spark and there is none, but when you let off the botton it will sprark for 1 sec. I have put in a working stater. I also tested the old one. It is fine. I took a e box out of my other ski and it did not work. That is when the new stater went in. I cleaned out the start stop switch and no luck. I have taken the white and black wire apart by the ebock and tried that no luck. I am going nuts on this one. If any one can help me out that would be great. I have the money to fix it. I just can not find the prob!!!!!!:dunce:
So if you can throw me a bone :hitwithrock:that would be great!!
