Whats The Best Trim For The $
THRUST
ThrustInnovations.com
the bond line you can trim out none or a ton its up to you . you really dont need to pull under power anyhow . just blip of the throttle pull in and this gives the pump time to load up and gas it
jetskier79
I'm goin' for two
San Diego, CA
jerry,can you pull it under a load on a surf turn? Didnt know you had one on a b1,has it helped your backie attempts any?
Unfortunately I didn't get a whole great amount of time with it before stripping the drive shaft on the blaster. I did test the ease of pull at different speeds. At 3/4 throttle it was still very easy to pull.
